Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
Is dit een goede vraag?
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
Was dit antwoord nuttig?
08033530020 Mr ola
Four wheel drive
@Olayanju Suraju what make, model, year?
Uses less if you don't drain the torque converter.
Well how manny qrts is less if u dont drain the TC??
Generally the tc holds about 4-5 quarts
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
2005 Ranger 4x4 with 3.0L or 4.0L engine takes 10.3 qts (9.8L)
Use Mercon V ATF
see page 233 of manual
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
How many liter atf for my ford everest 2005 model automatic transmission
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 73
Altijd: 55,340
2 opmerkingen
its a 1992 ford ranger 5 speed
door patsymiller0
patsymiller0, 1992 Ford Ranger 5 speed manual transmissionApprox 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
door L Pfaff
