Ga door naar hoofdinhoud
In augustus 2000 werd de negende generatie Corolla geïntroduceerd in Japan, met een scherper design en meer technologie om de modelnaam de 21e eeuw in te loodsen.
How do I aim headlamps?
I need the directions to aim the headlamps so I can see better.
Is dit een goede vraag?
Score 4
1 Opmerking
toyota altis 2005 headlight lamp how to adjust low and high ? left and right ?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ray, here are some instructions :
"Instructions
1 Park the vehicle close to a flat wall. Mark the horizontal and vertical center lines of the low beam lights with masking tape in order to have a reference point. Once marked, move your vehicle 25 to 30 feet away from the wall.
2 Locate the aiming screws on the light assembly. For stock headlights on the Corolla, there will be three screws total; one on each side and one at the top.
3 Turn the screw at the top of the assembly for vertical adjustments until the low beam light aims 2 inches below the horizontal center line.
4 Turn the screw on the left side of the headlight for horizontal adjustments to the right and the screw on the right side for horizontal adjustments to the left. Turning the screw moves the retaining ring and the adjusting plate within the headlight assembly against the tension of a spring, which in turn adjusts the headlight beam. The lights should be aimed just right of the vertical center line. from here. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ray zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 79
Altijd: 27,499
