Ga door naar hoofdinhoud
De vierde generatie van de Honda Accord, geproduceerd in de modeljaren 1990 tot en met 1993, beschikbaar als coupé, sedan en stationwagen.
How to do valve adjustment
how to do valve adjustment on 1991 accord lx
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
RAJ, here is the way the service manual describes it:"
- Valves should be adjusted cold when the cylinder head temperature is less than 100deg F. Adjustment is the same for intake and exhaust valves.
- If pulley bolt broke loose while turning crank, retorque it to 159 lb-ft
1. Remove Valve cover
Afbeelding
2. Set No. 1 piston at TDC. "UP" mark on the pulley should be at the top., and TDC grooves on the pulley should align with cylinder head surface. The distributor rotor must be pointing toward the No.1 plug wire.
Afbeelding
3. Adjust valves on No.1 cylinder
Intake: 0.010+/-0.01 in.
Exhaust: 0.012+/- 0.01 in.
4. Loosen locknut and turn adjustment screw until feeler gauge slides back and forth with slight amount of drag.
Afbeelding
5. Tighten locknut and check clearance again. Repeat adjustment if necessary.
Afbeelding
6. Rotate crankshaft 180deg. counterclockwise (cam pulley turns 90deg.) The "UP" mark should be at exhaust side. Distributor rotor should point to No.3 plug wire. Adjust valves on No.3 Cylinder
Afbeelding
7. Rotate crankshaft 180deg. counterclockwise to bring No.4 piston to TDC. Both TDC grooves are once again visible and distributor rotor points to No.4 plug wire. Adjust valves on No.4 cylinder.
Afbeelding
8. Rotate crankshaft 180deg. counterclockwise to bring No.2 piston to TDC. The "UP" mark should be at the intake side. Distributor rotor should point to No.2 plug wire. Adjust valves on No.2 cylinder
Afbeelding
Hope this helps, good luck
Was dit antwoord nuttig?
Score 5
7 opmerkingen:
What about the exaust valve's .
door
Do you do the exaust side at the same time you have The piston at TDC?
door
Yes, do it at the same time
door
Hey OldTurkey, Why do you have to rotate the pulley counterclockwise? Can you rotate it clockwise and get to the same place you want to go and not worry about the nut coming loose from the pulley? Just asking, Your the Pro.
Cheers, Alex
door
Noooo, it always rotates counterclockwise, I would NOT turn it the other direction
door
2 commentaren meer tonen
all Honda auto have a sticker under the hood that states on the left side to the bottom that states the specks intake /exhaust/ some are in metric intake 26 mm exhaust 30 mm -or intake .010/exhaust .012 I do like to push mine down 1mm to 25/29 since it has a lot of miles on it
Update (08/31/2015)
Score 1
4 opmerkingen:
firing order is from the timing belt side drivers side 1/3/4/2 on f22a1 engines an on most Hondas 4 cylenders
door
always go by your sticker under the hood no matter what anybody says
door
the best way to ajust valves is to get it ready the day befor an ajust the folling morning when it is as cold as possible for best job
door
What is the rocker arm assembly torque specs?
door
Voeg je antwoord toe
RAJ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 49
Altijd: 28,609
