Ga door naar hoofdinhoud
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
23 Vragen Bekijk alle
no Lcd backlight, the cable is damaged
Hi.
My camera's LCD is correct working,I can see things on it difficult. it's backlight cable is damaged and I don't have light under the LCD. how can I repair it?
my camera is Cybershot DSC-W55
can any body help me?
my English is not so good, I can explain more clear if you want..pleas help me :(
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
shiva, the backlight and the LCD are mounted together on this camera. You will have to replace the complete LCD to get your backlight fixed. Here is the guide for it. Hope this helps, good,luck.
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
tnx for answer.
I replaced the LCD! LCD and backlight! but my backlight is cut off and now it is not join to the that green board!! can i join it again by glue?
door
You mean the cable broke or is torn?
door
The cable is completely torn.. you can see my camera in these pictures.
http://upload7.ir/images/517939789278350...
http://upload7.ir/images/848897815152726...
the backlight cable is torn. :( can i repair it?
door
Sorry, but it does not look like you can fix that ribbon cable. You will have to replace the assembly.
door
and new question!
how can I test the inventer?? can you show me where is the inventer in this camera?? what is it like? I dont know is it works good or not!! how can i know?
door
2 commentaren meer tonen
Voeg je antwoord toe
shiva zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 562
