Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W55 LCD Screen Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: stap 3, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
    • Remove the panel.
  5. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Front Case: stap 7, afbeelding 1 van 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 8, afbeelding 1 van 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 8, afbeelding 2 van 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: stap 9, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 10, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Motherboard - First Half: stap 11, afbeelding 1 van 1
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 12, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 12, afbeelding 2 van 2
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 13, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 13, afbeelding 2 van 2
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: stap 14, afbeelding 1 van 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: stap 14, afbeelding 2 van 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: stap 14, afbeelding 3 van 3
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 15, afbeelding 1 van 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 15, afbeelding 2 van 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 15, afbeelding 3 van 3
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 16, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: stap 16, afbeelding 2 van 2
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Eddie Lo
334 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-20, Regan Fall 2010 Lid van Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 46
Altijd: 14,674
