Ga door naar hoofdinhoud
De Samsung Galaxy Nexus maakt deel uit van de NEXUS-reeks vlaggenschipapparaten van Google. Het toestel beschikt over een HD Super AMOLED-scherm, een gebogen scherm en Android-versie 4.0 Ice Cream Sandwich.
How to fix broken screen myself?
I dropped my Verizon Galaxy Nexus (SCH-i515) and the screen's outer glass broke. The display itself and the digitizer (touch sensor) seem to work just fine. Is there a DIY method of replacing the broken glass? I've seen the part (the glass front panel) online for anywhere from $15 to $25, but I've also read that the glass and the digitizer are somehow glued together such that it's necessary to replace the whole display (around $150-200!).
Any advice/links/tips would be most appreciated, including a list of needed tools to get this done. I'd just buy a new phone, but I still have a year left on my contract!
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Chris, check the teardown on here. It will give you a basic idea about what you are up against. It will also show you the tools needed. Here is also a decent video. Yes, the screen is a display assembly and I suggest to replace the assembly, even so you can probably purchase the individual parts, but they are extremely difficult to separate. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 3,174
