Ga door naar hoofdinhoud
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Vragen Bekijk alle
battery physical size (in relation with LG G2)
Hi,
may you confirm the physical size of the Nexus 5 is identical to this one of the LG G2?
Is it technically possible to buy the silicon battery of the G2 (3000mah) and install it in the N5 (same connector, same voltage aso)?
Is dit een goede vraag?
Score 4
2 opmerkingen
I'm also looking for an answer to this as I'm looking to purchase this-->http://www.smavtronics.com/3000mah-bl-t7...
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I4U, no you can not. The batteriy are different sizes
LG G2 BL-T7 size 55mm wide X 67mm long
Nexus 5 BL-T9 size 57mm wideX 60mm long
and the battery cable is on a different position.
Was dit antwoord nuttig?
Score 3
I don't know about the physical size but looking at the LG G2 user teardown and the Nexus 5 featured teardown:
  • Nexus 5 battery reference is BL-T9
  • LG G2 battery reference is BL-T7
  • mAh's are different
  • Finally the battery connectors looks not at the same places
I think we can conclude that you can't install a G2 battery on a Nexus 5, sorry. However, there is Nexus 5 batteries available on internet. Look for "LG BL-T9" on google and don't miss the Nexus 5 Battery Replacement guide on iFixit.
Nexus 5 Afbeelding
Handleiding
Nexus 5 Teardown
Moeilijkheid:
Gemiddeld
LG G2 Afbeelding
Handleiding
LG G2 Teardown
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
Nexus 5 Battery Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
20 - 40 minutes
Score 1
the size seems to be different
Voeg je antwoord toe
I4U zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 8
Altijd: 6,264
