Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Vragen Bekijk alle
iPod Classic White Screen but everything else works fine
Hey guys,
I have an iPod with 128GB SSD. This morning it suddenly dropped dead. I tried to reset it and the Apple logo appeared: everything back to normal.
But after about an hour when I pulled it out from my pocket it's dead again. The screen turned completely white and even if I reset it it's still white. I plugged it into my Mac and restored it, but the screen stayed white. As of this moment the iPod still works: clicker sound is still there and I can still play music. The computer recognizes the iPod and I can still use it as a disc.
I tried:
formatting it into FAT32.
reset and press Play+Select to enter disc mode
neither worked.
Anybody can give any advice? I'm really stuck. I'm trying to drain the battery so the entire logic board gets a fresh reboot now.
Thank you all for your time.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
azazkjkj, sounds like a bad LCD. The grey light only means that the backlight is still working. Once you disassemble your iPod, make sure that the display cable is still properly inserted and the the clip is properly securing the cable. If all that is okay, replace the LCD and see what you get.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
azazkjkj zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 25
Altijd: 2,718
