Ga door naar hoofdinhoud
Furby was een populair elektronisch robotachtig speelgoed dat lijkt op een hamster- of uilachtig wezen, dat na de lancering tijdens het vakantieseizoen van 1998 een periode lang een "must-have" speelgoed was, met continue verkoop tot 2000. Er werden 1,8 miljoen Furby's verkocht in 1998, 14 miljoen stuks in 1999, en in totaal werden er in de drie jaar van de oorspronkelijke productie meer dan 40 miljoen Furby's verkocht.
How to clean battery terminal corrosion
Hi I just found my two 1998 Furbies. They both look great on the inside however they have corrosion and I can't get them to work. Any ideas?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Erikka Holderness, corrosion should usually clean of with a vinegar/sterile water solution. Use a cotton swab or soft toothbrush to clean the contacts. Rinse with sterile water after that, you may have to repeat this step a couple of times. Once it is properly cleaned, use 90%+ isopropyl alcohol to displace any left over water (depending on where the contacts are situated). Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Ok great thank you p :-) I will be trying this.
door
I usually use a vinegar based rust remover and an old toothbrush. Then brush on some WD40 and let it sit and dry overnight, i dont even rinse anything, just wait for it to soak in and dry
Score 1
CLR also works well on battery corrosion after cleaning with CLR use wd40
Score 1
I use 90%+ isopropyl rubbing alcohol, with a q-tip/cotton swab and a paintbrush. I also have a diamond needle kit, that can scrap off heavy corrosion. Sometimes I'll use an soft toothbrush. Baking soda has abrasive properties, yet it's still gentle on electronics. Apply a small amount to the affected areas of your device, and rub it in to remove stubborn traces of corrosion. Then wipe the surfaces down with cotton swabs or a slightly damp, lint-free cloth. White vinegar or lemon juice also works, Most household batteries contain bases, so acids will neutralize their discharge.
Here is a video that might help with your furby: https://youtu.be/iMfin6TM0dE
Here is another video that might help with your furby: https://youtu.be/dJjl7CvBX2Q
Another video that might help with your furby: https://youtu.be/df9WG38gBLs
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Score 1
Battery acid is reported to be neutralized by white vinegar. A Q-tip soaked in vinegar can be used to remove battery leaking.
Voeg je antwoord toe
Erikka Holderness zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 166
Afgelopen 30 dagen: 749
Altijd: 30,003
