Ga door naar hoofdinhoud
Deze Apple Cinema Display wordt gekenmerkt door het modelnummer M8149 en werd voor het eerst uitgebracht in juli 2000
top half of screen dark
Dear all,
Can anyone give advice on how to fix the following? I have a Apple Cinema Display M8149 connected with and ADC-DVI adapter to a Mac Pro or MacBook Pro. Some time in the past the top half of the screen suddenly turned low in luminosity, right trough the middle of the screen. It still show an images but darker than the bottom half. So the top-half has half the luminosity of the bottom half. Feels like some fuse issue? Or maybe something else? Can anyone identify this problem and advice how to fix it? I ruled out the adapter (same problem with a new one) and the graphics card (same problem with different computer setup ). All help is appreciated!
Kind regards,
Marcel
Is dit een goede vraag?
Score -1
1 Opmerking
Be careful with what you spend on parts as this thing can be bought for under $80 now.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Marcel, sounds like either a bad inverter board or a burned out CCFL. I'd start with the inverter board since it is easier to replace than a CCFL.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Marcel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 921
