Ga door naar hoofdinhoud
Een externe optische schijf van Apple, in feite een rebranding van de MacBook Air SuperDrive.
How do I open the casing?
I have this external disc drive. There is a CD or DVD in it that wont eject. I hear it trying to catch the cd/dvd, yet I don't hear the spinning sound. Is there any way I can open the casing? I don't see any screws on t at all...
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
Steven, take a look at this guide.
Was dit antwoord nuttig?
Score 2
use a big suction cup to lift the bottom plate up so you will not damage the casing. this is what the official apple service manual says
Score 2
Without the suction cup, there are three simple snap tabs on either side of the case which can be pushed back with playing cards to open the case. You then need a Torx 10 and Phillips #00 or #000 drivers to remove three screws which hold down the drive in the case. After pivoting the drive up, you need to remove the two side Torx screws that fasten a mounting plate and 4 small Phillips screws to lift up the top plate and remove the stuck disk.
I was going to grant access to the paperclip eject hole I expected to find, but THERE IS NONE! If software won’t eject a disk in this drive, there is no option but DISASSEMBLY!
Jim
Score 1
1 Opmerking:
Thank you very much
door
Voeg je antwoord toe
steven zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 102
Altijd: 13,372
