Ga door naar hoofdinhoud
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 Vragen Bekijk alle
Vraag afgerond
To replace a 667mhz G4 PowerBook display and hinges
Hi, Can I use the lid and hinges from a G4 400mhz or 500mhz to replace the lid and hinges on my 667mhz? the right hand hinge on the PB has just ripped the lid apart after just over 7 years of good service. Display is still ok. But would like to replace hinges as per advice on this website.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You can use the hinges and the lid of the Ti VGA display but the VGA LCD screen wont work on your DVI Titanium.
Was dit antwoord nuttig?
Score 3
Disassemling a PB G4 Titanium screen is quite a pain, since lid and bezel are glued together. Good photoguide on the bookyard.
And, no, I don't have a connection to them, other that I sometimes buy a few nitbits from them.
Score 2
I'm not certain about the swap but perhaps these parts will work for you. Good luck Ralph
http://cgi.ebay.com/Apple-PowerBook-G4-1...
Score -1
2 opmerkingen:
Not the good hinges Ralph. Jim has a PowerBook Titanium...
door
Thanks for the response, but I'm none too sure where this leaves me. I don't want to attempt gluing or separating the hinges from the lid so does that suggest I need to find a 667 lid to match my 667 PB?
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,843
