Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
iPhone doesn´t charge even after repair it
My iphone 4 was charging very slow (10% by hour) and it didn't detect that its plugged, so I thought "May be the battery was dead", so I replace it and it didn't change. After that I decided that the dock connector is the problem, so i replaced it but the problem persist.
Maybe something on the logic board is damaged?
Is dit een goede vraag?
Score -1
3 opmerkingen
Like Vincent Monteil says, try a different cable as well as an AC adapter and see if that makes a difference.
door
I've tried with lots of cables even with a 30-pin to RCA and it doesn't stream video or audio
door
Have you checked the charging coil and components?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi jim !
In fact, people often think that the problem comes from a dysfunctional iPhone part. Actually, the problem could absolutely be your connexion cable or AC Adapter ! Do you use an official one ? Is it old ? I know that it can seem to be nothing but even if they are more expensive, you shall prefer using official new one. Your iPhone is mabe ok !
Let us know how it goes,
Hoping to have helped you,
Vincent
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
jimenezser zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 193
