Ga door naar hoofdinhoud
Repair and disassembly guides for Sony DVD players.
65 Vragen Bekijk alle
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
Is dit een goede vraag?
Score 5
2 opmerkingen
Mine takes awhile loading then says can not play this disc.
door
I wanted to know the spray that is used in cleaning of the lens inside the DVD
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
door
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
door
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
Push power protector
1 Opmerking:
Push
Reasonpower protector not working
door
Voeg je antwoord toe
Narni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 13,528
