Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Vragen Bekijk alle
apple support error
hello i got my ipod every time i turn it on my Ipod say www.apple.com/support/ipod?
i go there but theres no answes how to fix it. i tried doing a hard reset but that message still pops out? how can i fix this????
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Hi,
when the iPod says www.apple.com/support/ipod it most likely means that you have an hardware issue.
Connect the iPod to a PC and tell us what happens. If the iPod is unrecognized by the explorer and iTunes, it most likely means that the hard drive or the hard drive cable is damaged/broken. If the iPod is recognized by the explorer and not by iTunes try to restore the iPod via iTunes.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Easier said than done if iTunes doesn't recognise the iPod
door
Forgot to say that the iPod should be set to "Disk Mode" previous connecting.
http://www.command-tab.com/2006/03/30/hi...
door
Googling this message brought up a message the the ipod needs to be reset. I have included the URL for you. Ralph
http://www.zolved.com/synapse/view_conte...
iPod Videos are very finicky! Please take a look at the troubleshooting guide for further info.
Im having this same problem. The ipod is recognized by itunes, but when after the ipod is "prepared for recovery", I just get that same error message again :S. Does this mean it's the hard drive cable?
1 Opmerking:
cjdrake, this question is almost 3 years old. I suggest you ask your own question and give more detail.
door
Voeg je antwoord toe
djhugodaniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 3,799
