Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
How do you fix display that is partially covered in white?
After an insignificant drop, my iPod's display screen is now 75% covered in white. There are also thin colored lines running lengthwise down the display.
When I twist the iPod the white moves, but still covers most of the display.
I believe that the iPod is still functioning, as I am able to (in the area that the white is not covering) choose apps and they do appear (only partially of course where the white is not covering).
I purchased the iPod last Christmas and would hate to replace it with a new one if not necessary.
Any suggestions? Is there, perhaps, a part that I can install to correct this issue?
Any advice is greatly appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You can check the female cable receptacle for any bent / broke pins and reseat the cables. Or, plug in the old screen, if it works, you know the new screen is bad.
I pretty much can say after seeing this with several screens that I received in the past, it is probably DOA. It happens.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for your advice/help. Sounds like it may make more sense to just replace the entire unit.
door
You can replace the display assembly, but it is a very hard repair.
1 Opmerking:
Thanks for your advice/help. Sounds like it may make more sense to just replace the ipod w/a new one.
door
Take your time doing this repair I always run the battery out before I attempt this good luck
iPod Touch 4th Generation Front Panel Replacement
Voeg je antwoord toe
katrina zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 739
