Ga door naar hoofdinhoud
Uitgebracht in 2006, te herkennen aan het modelnummer E1705
video card not working need help locating same
video card does not work, it is built into the motherboard, or is it? Mine does not have a big video card as displayed in your pictures. There is a small green card plugged into the motherboard where it would appear the one you removed in the pictures. Is this little green card the actual video card ?
I have taken pictures if that helps.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Michael Crawford, that is a depends. "A removable (or discrete) video card is optional and present only if ordered by the customer. Standard video is integrated on the system board and is not customer removable." Download the service manual from here. It will help you to disassemble your computer, explain the parts to you, that way you will know what you have. you'll also find an excellent write-up on here. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Michael Crawford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 382
