Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Vragen Bekijk alle
Backlight not working after wine spill!
Hello,
After a wine spill on a 2011 Macbook air (A1369 EMC 2469) the backlight isn't working anymore.
The MacBook works fine, lcd is still functioning. Connected to a external display it also works fine, so it is probally not the graphic chip.
Did some research online, and found some hits about the fuse.
Does anyone have documentation about this fuse or what the problem could be.
Is dit een goede vraag?
Score 2
2 opmerkingen
Hi
Did you need a new logic board in the end??
any advice for similar problem?
door
Gav - You should post your own question as your details could be different enough to require a different answer. Use this question as a template on what is needed. Clearly a good set of pictures helps!
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Check the LVDS cable connector and the LVDS socket for any damage then also verify with a multimeter if the backlight fuse has continuity.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Where can i find the backlight fuse?
door
Sorry for the many comments, but on the last picture is this the fuse? with the P on it.
Multimeter gives me no continuity, so its blown.
door
Your logic board is in bad shape: LVDS socket and backlight fuse are damaged and we don't know yet about the led driver. You have three choices: replace the logic board, find a repair shop that has the tools, parts and expertise to replace the damaged components or use the machine as a desktop machine with an external monitor.
door
Het nuttigste antwoord
Before you worry about any fuses did you fully clean the wine out of the system? Make sure the right corner hinge area is clean (were the display is connected to the logic board)
Score 1
2 opmerkingen:
Logicboard seems to be clean, will take it out and will clean the other side too.
door
Your pics show a lot of burn damage on the logic bd and the LVDS connector. The traces maybe damaged beyond repair here. As Lemerise stated below your likely going to need a new logic board. Sorry guy ;-{
door
tonversteeg1, yes the "P" is a fuse. Your display connector appears to show a lot of damage, so you may have to repair the connector as well as the circuit to it. That may be the reason for you bad fuse as well. The fuse is a 2AMP-32V 0402-HF and for more information on the fuse, check on here http://elcodis.com/parts/117249/0435002K...
3 opmerkingen:
I agree with oldturkey, the P ic is the backlight fuse. Both the LVDS socket and connector are damaged et must be replaced. There's also a possibility of a LED DRIVER damage.
door
Ok, thanks for comments.
Will order a new LVDS connector and a LVDS cable.
Only need to find someone who can do the job.
Does this Macbook pro LVDS connector also work?
http://www.ebay.nl/itm/Brand-New-MacBook...
door
I would contact ebay sellers who advertise the LVDS connectors and ask them if they have your MBA connector in stock. The backlight fuse may be available online at http://www.digikey.com but I don't know your MBA fuse specs...sorry.
door
Voeg je antwoord toe
tonversteeg1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 10,338
