Backlight not working after wine spill!
Hello,
After a wine spill on a 2011 Macbook air (A1369 EMC 2469) the backlight isn't working anymore.
The MacBook works fine, lcd is still functioning. Connected to a external display it also works fine, so it is probally not the graphic chip.
Did some research online, and found some hits about the fuse.
Does anyone have documentation about this fuse or what the problem could be.
Is dit een goede vraag?
2 opmerkingen
Hi
Did you need a new logic board in the end??
any advice for similar problem?
door gav
Gav - You should post your own question as your details could be different enough to require a different answer. Use this question as a template on what is needed. Clearly a good set of pictures helps!
door Dan
