Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iPhone 5 water damage!
i dropped my iPhone 5 in water or I had it in my pocket in the washing machine.. but now i dont start it just start when i plug the phone to the PC but i just goes to recovery mode an i get an error 2001 error and i have tried DFU mode and i get the same error, the battery is dead i think.. is it possible and fix this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Christoffer Solbrekke, as with any iphone, I strongly recommend that you clean it. Disassemble it by using these guides. Clean it properly using this guide. It was written for a 3G but all the points still apply to your phone as well. Once it is properly cleaned '''replace the battery" reassemble and re-evaluate. With a new battery and properly cleaned, you will have a good starting point should any further trouble shooting be necessary. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
Hey Christoffer, you can try drying the phone for two days using Rice or Silica Gel. Do not turn on your phone after water damages, dry first and then turn it on. If this does not work seek professional help. Please see the instructions here: http://www.technobezz.com/how-to-fix-a-w...
Score -2
1 Opmerking:
carolinemyers13 "for two days using Rice or Silica Gel" doe not do anything. Reice does not fix things and will not stop corrosion. Bad advise.....
door
Voeg je antwoord toe
Christoffer Solbrekke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,236
