Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Vragen Bekijk alle
Vraag afgerond
Is 70% Isopropyl alcohol ok to clean an iPhone 3GS?
I was caught in a heavy rainstorm about 3 days ago and my iPhone died on me. I opened it up when I got home and dried off the components with a soft cloth as well as ordered a new LCD & Digitizer and installed those.
The screen works as it should but the backlight is still inactive.
My question is: Is 70% isopropyl alcohol enough to clean the logic board and connectors of the 3GS? I was planning on following the guide posted on this website inorder to do the fix but was just wondering if 70% was too little of an alcohol concentration.
Thank you for any help you may be able to provide.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No. 70% isopropyl is 30 % water. Use methanol.
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
So if I were to soak or brush the contacts with it it would just ruin the phone further? Also, would 90% or 99% be the right choice then?
door
90% + should be fine.
door
And 90%+ is available at places such as Target or Walmart correct?
door
Andrew Novotny, I get my stash of 99% through my local pharmacist. The larger retail stores are not really good in getting those items, not a big selling item for the.
door
I don't know, I use Methanol. Call them.
door
1 commentaar meer tonen
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 1,700
