Ga door naar hoofdinhoud
Uitgebreide reparatiehandleidingen voor elk van de zes versies van de iPod Original. Veel voorkomende reparaties zijn het vervangen van de batterij en de harde schijf.
2160 Vragen Bekijk alle
Vraag afgerond
My I pod wont sinc with itunes then freezes when I try
I try to sync my 30 gig i pod with itunes and the computer tells me i cant sync then when i try to anyways it freezes
Is dit een goede vraag?
4 opmerkingen
Can you tell us any more? Does it play? Any other problems?
door
my sisters i pod froze
door
ruben, you will have to give more information. Like, what iPod is it did anything happen to it? When did it start freezing? What have you done about it. It would help it you click on the link on the right side of this page "Ask a Question" and give as much detail as possible. Good Luck
door
I have an iPod 5 video that won't reset and is not being recongized by my computer. Is this a board or harddrive issue?
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
My friend you might want to try this and see what happens next...Try deleting your itunes softwear and update to the most current itunes softwear. If this doesen"t help change your hard drive...
Was dit antwoord nuttig?
Could be a corrupt iPod music library file.
If you have all of your iPod music already loaded within your iTunes library, try resetting the iPod via iTunes to factory settings.
Next, sync the iPod with iTunes to transfer back all the tracks and playlists.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 670
