Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
What value is that small part near blue inductor?
Hello I have asked here earlier about BB crashes (What may cause BB 05.13.04 crashes? (unlocked by ultrasn0w))
I was missing that small part close to blue SMD part (probably both are RF inductors, but who knows) and I applied some sort of this fix http://matteopisani.altervista.org/iPhon...
My iPhone could not get service (BB was always crashing a it got service for maximum few minutes..), so I presumed that if it's low inductance inductor it could be replaced by blob, so I made tiny tin blob over it's contacts..
It helped a lot 70-80% of time I have full bars, but the problem is that it's very picky to location and wether I use GPS or WiFi... For example if I take elevator in malls it lose service and it takes 10-20 minutes sometimes even hour of Searching/1 bar/no service to pick it back..
It seems to pick it instantly if I open phone and disconnect battery and connect it back and turn phone on, but that's really useless when I'm not at home and can't open it up..
So my question is, what is that part I am missing? (http://matteopisani.altervista.org/image...) Is it really inductor? And if it is what value is it, I was thinking about unsoldering blob and either buy it at Farnell or in local "radio shack" or making my own by taking really thin transformer wire and wind it on needle.. But I have no idea what inductance it should have..
Is dit een goede vraag?
Score -1
1 Opmerking
Hi there I have the same problem but now I've knocked the BLUE chip off and lost it..:( have you any fix or what the chip is called???? Thanks Dwain
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Bruno Kremel , the part you are pointing to with you image is L3_RF = 7.5 nH, 5 %, 680 mA, 0.104 Ohms, 5800 MHz SMD/SMT 0402 (1005 metric) Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thank you very much... going to calculate wire length needed for this.. :)
door
I have found it on Farnell, is it this http://uk.farnell.com/jsp/search/product... ?
door
Yes Sir, that looks correct :-) good Luck and thanks for accepting my answer :-)
door
Is this blue coil same for 3g / 3gs / 4 / 4s ?
Voeg je antwoord toe
Bruno Kremel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,107
