Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Vragen Bekijk alle
Vraag afgerond
YLOD (After using kit)
Hello there,
So I had my power flicker the other day, and later that day the ps3 played a movie for about 20 minutes then turned off.
I was then getting the issue where it powers on, yellow light, then red. And then the red light would just blink.
I bought the YLOD kit and followed it to the letter. My PS3 doesn't have the memory card reader so it was slightly different but I got around it.
Afterwards, I booted it up and it came on! I was so happy, I ran it for a few minutes and then powered it down. About ten minutes later, it came on to the menu, froze and started doing the light thing again!!
Is there anything else I can try before I give up and buy a new one?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Ropiak86, this is very common for the first couple of attempts. The problem is that we all seem to under treat the heat part. I would suggest you try it again, step by step, but use the heat a bit more aggressive, just not careless.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you for your comment. The guide suggested 25 seconds on each of the 4 sections. Would you recommend more time on low setting for each section? Say a full minute? Thanks!
door
Don't focus to much on the time. Use a slight sweeping motion to ensure that the balls reflow nicely. remember, that the solder should not melt, just liquify enough to reflow.
door
I ran the ps3 for about 20 minutes without issue and a restart. I'm going to cross my fingers that it's still working. Thanks for advising I go back in and redo it. I wouldn't have bothered otherwise!
door
Good job getting it done. It does take a bit of practice and a lot of luck. sometimes it last for a good while and other times it gives out quickly. Consider having a professional reball done for a much more permanent fix. Your console is definitely worth it. Again, great job....:-)
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 636
