Ga door naar hoofdinhoud
Afgezien van de Tahoe Limited Edition werd het voertuig voor het modeljaar 2000 opnieuw ontworpen op het nieuwe GMT800-platform, dat nog steeds werd gedeeld met de full-size pick-ups en SUV's.
Location of radio amplifier?
My amp keeps cutting out, shuting off the sound. The radio keeps working.
Is dit een goede vraag?
Score 7
12 opmerkingen
2002 Yukon radio cuts in and out. Every once in a while will radio works Could this be amp.
door
I some help as well mine is doing the same thing
door
I havev2006 yukon xl,i put in a aftermarket radio & now I have no sound but through radio comes on & i dont have no power to my charging outlets,how can I fix this
door
Mine doing same thing you figure it out yet
door
i have a 2002 Yukon xl. I replaced the stock radio with a kenwood. I bought the adaptor and installed the radio. the stereo lights up but there is no sound from any of the speakers.
i know the radio works with this same adaptor. we tried it in my friends jimmy
door
7 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Rick McAninch, you did not give us a lot of information about which year your Yukon is or which amp. I assume it has the Bose system. Should be inside the center console, just pull the cup holders up to see if it is there.
AMPLIFIER REPLACEMENT
REMOVAL PROCEDURE
1. If equipped with a Bose(TM) amplifier, remove the radio amp fuse located under the hood electrical center.
2. Remove the floor console bezel.
3. Remove the cupholder.
4. Remove the bolts (1) retaining the console to the instrument panel (I/P).
5. Remove the console storage bin.
6. Remove the center console end panel.
7. Disconnect the audio amplifier electrical connectors.
8. Remove the 4 screws retaining the upper console bracket to the lower console bracket.
9. Move both front seats to the fully forward.
10. Reposition the inboard seat track trim (1) in order to gain access to the rear console side panel screw (2).
11. Remove both rear console side panel screws
12. Move both front seats to the fully rearward.
13. Remove both front console side panel screws (1).
14. Disconnect the floor console electrical connector.
15. Remove the console assembly from the vehicle.
16. Remove the audio amplifier screws (1).
17. Remove the audio amplifier from the vehicle.
Hope this helps, good luck.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
How do
I tell if it's the radio or amp.
door
Sound in my 2002Yukon goes on and off after new stereo installed
door
Is the antenna plugged in?
Update (10/24/2017)
I have a 1999 yukon denali with RPO code Y91... I completely removed it cause I think they are crap. And installed after market amp HU and speakers including sub of course. But if the radio is not working.. make sure antenna is plugged in or if you have a powered antenna make sure that remote turn on wire is hooked up.
Score 1
I have a 2005 Chevy Silverado 1500 LS Z71. I installed this unit ( http://www.ebay.com/itm/Car-DVD-CD-Playe...) and everything works except the radio looks just like the screen shown in the video, but no sound and it will not allow me to change the stations... I get sound from the DVD, NAV, BT, but the radio goes blank, no sound and stations will not change using the touch screen nor does it work using the tuner knob.
3 opmerkingen:
On a 2011 Yukon Denali with a Bose System, is the amount on each speaker?
door
Is the amp on each speaker?
door
I have a 2003 GMC Yukon and when the truck is cold the radio won't work but when it warms up after driving for awhile it kicks in all of a sudden, and also I only have sound coming from the passenger side front door and pillar post tweeter and back tweeters by tailgate but no other speakers work.
door
the amp turn on wire in a 2001 Yukon xl without Bose and WITH a factory subwoofer is located in the 9 pin connecter from the back of the radio and the color is pink. you need to run the remote wire from the aftermarket deck to the pink wire.
There is a big problem with using the amp factory amp as is in this setup because the amp has 2 functions: its a LPF and amp for the sub as well as a HPF crossover for the door speakers. I suggest you bypass the crossover portion and leave the amp portion. This is easily achievable if you follow these instructions:
http://www.savagehomeautomation.com/proj...
I also had a factory subwoofer in very bad shape when I bought this truck but I fixed the speaker in about 15 mins using this kit:
https://www.simplyspeakers.com/panasonic...
I hope these things help you as much as they helped me.
Enjoy!
1 Opmerking:
Thank you...the pink wire for stereo turn on....
door
Voeg je antwoord toe
Rick McAninch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 114
Altijd: 84,838
