If you have Xbox with built in wifi do you need adapter?
I am gettin a Xbox with built in wifi since it has built in wifi do I need to buy network adapter???
Is dit een goede vraag?
Nope, it should connect to your wireless network without major issues. just make sure that your router uses the 2.4GHz band of wireless-n. The built-in wireless adapter in the Xbox won't communicate on the 5GHz band. the network adapter would only be required if you did not have on board Wifi
Was dit antwoord nuttig?
Heu got another question how do I find out if I have a good enough router do I like at I'd number I don't think I have the box still??
Take a look at router itself. Should have Manufacturer and a serial number on it
I know that it is a Belkin wireless router but should I type Id numbers into google and see what ghz it is?
I have a model v4 belkin wireless router do you know how many ghz is it I can't find it plzz help
Take another look at it v4 is usually the version, most like a G series. Check to see if you find a number like this F5D7234-4 for example.
No, you don't need wifi adapter. If you have problem with built in wifi then you can go for microsoft xbox one wifi adapter.
Yes, I agree with USB Wifi Adapter. If your built-in wifi not works you can also troubleshoot the problem as well as you can replace wifi card for Xbox one.
i have a built in wifi adapter and it doesnt work and i dont know why so is there a way to fix this problem
this is my usb that wont work and i want to know if i can fix it
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 6,434
3 opmerkingen
Depends on if you have wireless in your home. :)
door oldturkey03
Yes I do So would I need adapter
door evinghams
Thank you for all the help much appreciated
door evinghams
