Ga door naar hoofdinhoud
Repair guides for Dell Inspiron laptops. A line of mid-level Dell laptop computers.
Add Boot Option using Insydeh20 setup utility
Hi,
I have a Dell Inspiron 7520 (i7 processor) laptop. When I tried to start my system it showed the spinning icon, and after few seconds, it showed me a blue screen with the following error message:
"Your PC ran into a problem and needs to restart. We're just collecting some error info, and then we'll restart for you".
Once it shows the above message, the system restarts and then repeats the same process of showing the same error message and restarting. This keeps happening in a loop.
The software running in the BIOS is Insydeh20 setup utility.
I managed to get a copy of Windows 8 on a USB drive. In order to boot from the USB, I got into the Bios (using F2) and tried to "Add boot option," as there were no other boot options present. When I tried to do that, it asked me to provide a name. I entered "USB". It then added it & allowed me to edit properties of this option. When I tried to edit the property, it asked for File system path. Because this is a USB drive, I do not have a clue as to what this value should be & how to set this USB drive as the first priority.
Any instructions on how to set the file system path for the USB drive and how to set it as the first priority will be greatly appreciated.
Thank you.
Is dit een goede vraag?
Score 11
11 opmerkingen
Did you make your USB drive bootable when you copied Win8?
door
I have 7520 and I can't boot from USB pen drive.
Dear oldturkey03! The problem isn't the booting capable of pen drive. The real problem is a BIOS of 7520, because we can't set the boot device to USB.
door
Thank you for this.
door
Make it(USB) first in BIOS or just press f12 to acces boot menu make sure there is no other media before USB flash nice to see that it`s solved.
door
This trick is also not working
door
6 commentaren meer tonen
Voeg een opmerking toe
14 Antwoorden
Gekozen oplossing
I had this issue—most irritating. I have a 7520 i7, with insydeH20 A9 BIOS. The issue is UEFI. You need to enable legacy boot.
  • Start the machine and hit F2 to get to BIOS.
  • Disable secure boot in the boot options screen.
  • Enable the load legacy option ROM.
  • Keep the boot list option set to UEFI.
  • Press F10 to save and exit.
  • Shut down the machine and start it again with the USB device attached.
  • Press F12 on boot to get the legacy boot options.
  • Pick USB from the list, and off you go.
Was dit antwoord nuttig?
Score 54
33 opmerkingen:
Thank you Graham White, your answer works perfectly!
door
Brilliant, worked perfectly, thank you.
door
i have a hp 245 bassed on linux suse, your configuration works! thank you so much
door
Thanks, workt perfektly on Lenovo G710 withinsydeH20 rev 3.7
door
Same problem but, when the USB device is added, I cant scroll down to choose it! What am I doing wrong?!
door
28 commentaren meer tonen
You need to create a UEFI specific boot USB drive to boot usb devices with a UEFI system. Some Dell models (like my new Inspiron 11) doesn't even have a legacy mode.
1) Disable UEFI secure boot (this is a key exchange that occurs for an installed system)
2) Create a UEFI enabled Windows OR Linux usb drive (MUST be formatted FAT16 or FAT32):
Unbuntu: https://help.ubuntu.com/community/UEFI
Windows 8: http://www.eightforums.com/tutorials/154...
3) When you boot, press F12. If done correctly, it SHOULD show up as a bootable device.
Just went through this crap tonight and randomly answering forums in hopes of saving other people from this headache!
Goodluck!
Score 3
1 Opmerking:
That is not help
door
Try adding the files to a bootable CD and try booting from the CD, this is what i would do in my own opinion.
Score 1
Usb boot option not show in boot menu, how i add USB option in boot memu, acer aspire 3
1 Opmerking:
Rahmath - It would be best to create your question with all of your details as I doubt anyone will see your post here as it's so old (2012)
door
Ok seems it`s not fixed
Step 1) Disable legacy protection if it has by entering your own password in BIOS, then disable legacy protection.
Step 2) Choice your way to fix this because there is 2 ways to fix this: Install Windows To Go on Flash drive and boot it from PC\Laptop second way is use two flash drives one where is installation second flash drive is need to use for place OS like Windows 10,8,7,Vista,XP Linux, iOS etc.
Step 3) If you choose version Windows To Go you need only one flash where to install it before it you need to get Software called Rufus at site: https://rufus.akeo.ie/downloads/rufus-2...., after download it run and it will show drive to install choose your and select disc icon after that browse your selected ISO installation if it has Windows To Go Rufus will automatically show this option if it has, like almost all ISO downloaded from Microsoft, msdsn.microsoft.com etc. it will take long hours but you will get OS installation on any Flash drive where is enough free space, reboot PC\laptop make sure USB flash drive is in first BOOT UP place set by BIOS. All OS is on your flash without any BOOT option straight by Rufus
Step 4) If you choose version 2 flash drive version you need 1 flash with OS installation files like Windows 7 and 1 flash drive where to install it, you can use similar software Rufus to write in flash OS installation without checking Windows To Go version in Rufus this is fastest way to install OS. When it`s start up Windows boot from flash installation you just need to choose drive like new 1 flash drive it will 100% install to it if you select it in installation time when installation is started.
Step 5) Check Disk formation - if you ask about File system installation than you need to use program called Command prompt or CMD you must run as administrator this by making shortcut on Desktop by right mouse click on desktop->new->shortcut and locate your CMD like C:\windows\system32\cmd.exe, now on new made shortcut right click->properties->Shortcut tab->Advance->check Run as administrator->Ok->Ok now you have CMD with administrator rights. Now just open new shortcut->type diskpart-> hit enter-type list disk->hit enter->type select disk(your flash drive watch who it is like:1 now command to type looks like: select disk 1-> hit enter->list partition->select partition 1->Delete partition->create partition primary->Now go to my computer open Flash drive it will ask Format drive click on it, but remember files larger than 4GB need NTFS file system so use NTFS before formatting new flash drive->Click format. After formatting flash Drive in large file system like NTFS you can install most newest OS on your Flash drive if that`s you wished to know.
i have lenovo G560 laptop and i am getting problem to slow boot, issue of bios. my laptop has h2o insyde bios (2.18) plzz solve my problem related of booting process.
I wish to answer to shubham sen
You need to open Event Viewer in Control Panel then locate Windows Logs/System you must repair all red error messages what shows up by Event notification system they are not critical but if you do that than all your boot time must be fixed it`s usually Component Services Dcom Config security permissions otherwise PC will boot slowly and full of errors, like you need to change permissions before you do it in Dcom Config in Windows registry by yourself if you are using Windows.
Yоu need to сrеаtе a UEFI ѕресіfіс boot USB drіvе to bооt uѕb dеvісеѕ wіth a UEFI ѕуѕtеm. Sоmе Dеll mоdеlѕ (like my nеw Inѕріrоn 11) doesn't еvеn hаvе a lеgасу mоdе.
I'm currently installing Gentoo on a Dell Inspiron 15 (3521 - Celeron 1007u CPU, 4 GB RAM, and an Intel X25-M [gen 2] 80 GB SSD with the same InsydeH2O uEFI interface {that suspiciously looks like a plain old BIOS interface) with secure boot on. Once I figured out how to give it the parameters that InsydeH2O wants / needs, I was able to leave secure boot on, enable the custom settings, and set up 3 devices that the laptop is allowed to boot from:
  1. The HD
  2. My USB drive with SystemRescueCD (a uEFI compatible live CD that is based on Gentoo, so perfect for use in installing Gentoo)
  3. A Windows 10 USB made using the Media Creation tool
I'm actually in the middle of that install, so I cannot reboot at the moment to take pictures, but as soon as I am able to, I'll make a full post on what you need to do, and where you need to do it, so that you'll then be able to keep secure boot on and boot Ubuntu.
Getting the HD to boot Gentoo is a bit trickier, thus far, as I am also using rEFInd as a bootmanager for the laptop, and by default it wants ot use a path that seems to be too long for InsydeH2O's custom boot settings, so I am playing around to get that working as I want it to. However, with Ubuntu, as long as they follow the normal efi specs on file locations (namely, .efi files located in \efi\boot\) you should be able to install Ubuntu to the HD, then go back into InsydeH2O again and use the same procedure to allow the laptop to boot from the HD itself.
Feel free to send me an email if I happen to forget to come back here :)
My Toshiba C650 laptop doesn’t taking boot(windows 7 pro 64 bit) from pen drive… and it BIOS ( InsydeH2O rev 3.5 ) doesn’t have any option like uEFI enable or disable , secure boot enable or disable.. i have already set priority in boot menu… still it doesn’t accepting boot while my pre-installed windows XP gets crufted what to do help if anyone of you know the solution…. please its urgent
1 Opmerking:
I'm having the same issue.
door
For dell
-plug win10 usb (uefi and secureboot ready)
-f2 setup
-enable uefi boot, disable legacy option rom boot, enable secureboot, enable ahci
-go and add boot option
-give it a fancy name
-choose usb under FILE SYSTEM LIST (look carefully to see USB written in one of several entries and choose it)
-click … dots
-find bootx64.efi under efi\boot directory (FILE NAME entry should look like \efi\boot\bootx64.efi
(If you have a small netbook you may need to choose bootia32.efi file)
I have a compaq presario laptop and i am trying to format it when I enter the BIOS the up and down arrows wont work so i can choose the boot options (or anything else), everything else in the BIOS works perfectly. How can I fix this? BIOS version: insydeh20
plz some one help me my toshiba is stuck in insydh20 rev3.5
what to do ?????
it is is very simple
 just go to the security part in the BIOS
Put a password for your hard disk as well as administrator
Immediately you will see an option which will let you enable or disable uefi
Once you have got the option,  just disable it
 next time you will get all the choice for boot sequence including USB boot
1 Opmerking:
Do not use Rufus it has errors like 0x80070050 Radeon error 1603, sleep is definatly destoyed and so on it can even destroy your PC Windows license
door
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 95
Afgelopen 30 dagen: 429
Altijd: 398,496
