Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Vragen Bekijk alle
Vraag afgerond
Home Button Without Replacing Cable
I want to switch colors of my digitizer. The kit I am looking at just has the button not the whole Home Button Assembly. How is this button held on to the cable, the standard adhesive they use to hold other parts on? Do you remove the button with a heat gun? TIA
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes, it is held by the standard double-sided adhesive that Apple uses in many places of the iPhone. Gentle use of a heat gun can be used but is not necessary. Just carefully pry the Home Button part you touch from the Ribbon part.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 404
