Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Walkie Talkies won't connect
"I want to use the Walkie Talkies, but they will not connect to each other"
Power
Check to make sure there are batteries in both devices, then turn them on with the power button.
Connectivity
Once the devices are on, click and hold the Mode button until both devices are connected.
Walkie Talkie won't turn on
"I want to use the Walkie Talkies, but I can't get them to turn on"
Power
Check that the devices both have batteries in them. On the back of the device is a cover that must be removed in order to put batteries in. When batteries are in device, the Power Button needs to be switched over to turn on the device.
Camera won't work
"When the Walkie Talkies are connected, the front-facing camera won't work"
Connector
After opening the top part of the toy, check and see if the ribbon connector is fully plugged in and has no faults or tears. If it does, the camera needs replaced. As long as the female end is connected to the board well, then then the camera needs replaced
Audio Troubles with headphone jack
"When using headphones, I hear no sound coming through"
Testing
Test headphones through phone or computer jack to assure headphones work properly.
Spotty Sound
If sound is spotty through headphones, audio jack may be loose. In this case, take the device apart, locate the headphone jack, unsolder the jack, and find a replacement.
Screen broken or not working
"I opened the Walkie Talkie and the screen is broken and I can't see anything"
Broken Screen
If the screen is not working or broken then you will have to replace the entire circuit board on the top part of the toy. The screen is soldered to the board directly by a ribbon.
Buttons sticking together
"I was trying to change the volume and it wouldn't work because the buttons were moving together"
Connected Buttons
If the buttons next to the screen are sticking together then remove front cover and then break them apart simply by bending them where connected.
2 opmerkingen
ifixit Walkie Talkies won't connect i thinh so good " When using headphones, I hear no sound coming through" i likeit click here .http://dialongdanang.com/san-pham/phu-ki... thank you blog
nguyen vuong - Antwoord
Won't turn on I put new batteries in and still didn't work
Makena Wilkins - Antwoord
