Paginabegin
This wiki page is a stub. Help us improve this page by adding information to it!
Hair Dryer Won't Turn On
Check your power source
First, make sure the plug is all the way in the socket. If need be, reset the outlet, and/or the hair dryer plug itself. If the dryer still won't turn on, you may need to replace the switch. To do so, visit our On-Off Switch Repair Guide.
Cool Down Setting Not Working
Cool Down Button may be broken
First, make sure you give the dryer a second to cool down once pushing the cool down button. If after a 30 seconds the air is still hot then the button may be broken. To fix it, visit our Cool Down Button Repair Guide.
Cord Not Retracting
There may be a jam, or the button may be broken
First, hold down button and pull the cord out a little bit, and try to feed it in. It should start to retract after this. If it still won't retract, you may need to use our guide for Replacing the Cord Retracting Button, or our guide for Replacing the Cord Retracting Mechanism/Wheel.
Damaged Front Fan Grill
If you have dropped your hairdryer, the front grill may be loose or dented
If you want to replace this part, visit our Front Fan Grill Replacement Guide.
1 Opmerking
My problem is the buttons to reset the hair dryer plug won’t work. Any suggestions?
kslcoates - Antwoord Deel
