Inleiding
If the cord from your Conair Cord-Keeper 169XR hair dryer isn't retracting and your retracting wheel is working fine, then the button may be broken and would need to be replaced.
Wat je nodig hebt
Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
Remove the inner white disk piece by gently pulling it out with your finger nail.
Once the retracting wheel is off, you can get to the retracting button and gently remove it by pulling it out of the groove it is resting in.
Now you just need to replace it with a new one. (The stem of your button may have broken and stopped activating the retracting wheel).
