Inleiding
The iPhone 13 might look like an incremental update from the outside, but we’ve got a feeling there’s more lurking beneath the surface. We took a quick peek inside during our 13 Pro livestream, but let’s spelunk a bit deeper into the iPhone 13 Pro to see what secrets we can uncover.
To be the first to see inside the latest gadgets, follow iFixit’s YouTube channel, our Instagram, and our Twitter, and subscribe to our newsletter!
Wat je nodig hebt
Video overzicht
While the regular and mini get some of the cool new tech for this generation, the iPhone 13 Pro gets it all. Here's what's on the menu:
A15 Bionic SoC with a new 5‑core GPU, 6-core CPU, and 16‑core Neural Engine
6.1-inch (2532 × 1170 pixels) Super Retina XDR OLED display with ProMotion
12 MP triple camera system with an ultra-wide angle (ƒ/1.8), wide angle (ƒ/1.5), and 3x telephoto (ƒ/2.8) cameras, plus a LiDAR module.
6 GB of RAM and 128 GB of storage (configurable up to 1 TB)
Sub-6 GHz 5G (and mmWave on the US models), 4x4 MIMO LTE, 2x2 MIMO 802.11ax Wi-Fi 6, Bluetooth 5.0, Ultra Wideband, and NFC
MagSafe 15 W wireless charging
IP68 water-resistance rating
Compared to the 13 Pro Max, this lil' Pro is just right for our teardown. But it's not the size that counts, it's the insides!
You can see a double dose of L-shaped battery, claiming every millimeter of space they can. We first saw these back when iPhones had letters for names.
We also see stabilizing magnets for the image sensors, tiny logic boards, and some potentially smaller Taptic Engines?
From the outside, this lucky number 13 looks a little swollen compared to last year's model. The camera bump has bumped up so much that the phone doesn't lay flush on a flat surface! Not that the 12 did either, though. Sigh.
Can I get some sweet iPhone 13 Pro wallpapers like was done last year for the Max?
But, iFixit, what if I don't need to fix my iPhone and I just want to stare at its gorgeous guts? We've got you covered with these nifty Pro Max wallpapers.
We’ll have wallpapers available next week!
Good thing we've been practicing opening and closing our 12 Pro for weeks! The 13 Pro thankfully inherits one of our favorite smartphone opening procedures. The display comes off first, like opening a book. A ... slightly sticky book.
Inside, we immediately spot some surprises—and some handsome labeling! It's almost like they were expecting us.
For starters, the digitizer and display cables seem to have joined forces. The upper sensor cable is off on its own near the top (and is scary thin and way too short).
The Taptic Engine appears smaller than the 12 Pro's shaker, but it's actually bulked up, clocking in at 6.3 grams and 869.4 mm³, versus the 12 Pro's 4.8 grams and 764.27 mm³.
Let's spot the differences between the 13 Pro (shown left) and 12 Pro (right) shall we? First off: no more display-mounted earpiece speaker! Easier display replacements, but irksome earpiece replacements (more on that later!)
And second, a missing cable (one we didn't notice was also missing in the 12 Pro Max as a matter of fact!)
The Notch™ is 20 percent narrower on the 13 Pro compared to the 12 Pro, thanks to Face ID's flood illuminator and dot projector merging into a single module! (Also more on that later! Noticing a pattern?)
The notch in the 13 series is actually slightly deeper than the notch seen in previous models! You can see this when you compare an iPhone 13/13 Pro and, say, an iPhone X displaying 18:9 video: The 13’s notch cuts into the side of the video ever so slightly, while the X’s notch does not.
You can see a comparison here: https://twitter.com/ParkerOrtolani/statu...
Well that sucks…
Look Apple, we can rack focus, too! Our cinematic prowess stars the LiDAR module glancing suspiciously at the hefty camera trifecta.
Unlike the vanilla iPhone, this year's Pro camera arrangement looks the same (and noticeably beefier than the 12 Pro's array). How will people know you've upgraded now?! Maybe you should just… not?
No wonder that bump is bumpin'. These camera lenses are reaching for the stars to gather as much light as possible!
is the lidar module the same as on the iphone 12 pro ?
Were you guys able to confirm that the camera module on the 13P and 13PM is the exact same, part number and all?
Can anyone tell me what hirose FPC connectors are used? It would be nice to have a list of each component. I have seen Chinese companies produce break-out boards for some sensor and battery connections. It would be nice to have a list of these as replacing them sometimes is what is needed.
Gereedschap gebruikt in deze stap:Moray Driver Kit$19.95
We bust out the loudspeaker and Taptic Engine to get at the battery, thanks to the Moray driver kit!
The clean, minimalist printing mimics the clean, minimalist removal procedure. We can't praise stretch-release adhesive more highly, though we'd love easier access to the tabs...
This beefy L caps out at an expected 11.97 Wh compared to the 10.78 Wh obelisk found in the iPhone 12 Pro (and non-Pro), but loses out to the standard's 12.54 Wh rectangular cell.
None of these three hold a candle to the 17.8 Wh behemoth in the Xiaomi Mi 11, not to mention Samsung...
We can finally let out the breath we've been holding: after some rumors that battery swaps wouldn't be possible this year, we're happy to report that our early battery swap tests were all successful!
Apple hasn't given up its scare tactics, so you'll still get a warning notification. Be brave and keep fixing!
The layered logic board is even teensier this year, and unfortunately the SIM card reader is now baked onto the board (booo!). In any case, let's see what chips are lying on the surface:
Apple APL1W07 A15 Bionic SoC layered with what's most likely 6 GB of SK Hynix LPDDR4X SDRAM
Apple/USI U1 ultra-wideband chip
Apple APL1098 power management IC
Skyworks SKY58276-17 front-end module
Skyworks SKY58271-19 front-end module
Apple 338S00770-B0 power management IC
STMicroelectronics STB601A05 power management IC
The PMIC is actually APL109B not APL1098. That is the A2442 14" macbook pro's PMIC.
This is one time where blowing hot air is beneficial. Here's what we find inside this silicon sandwich:
128 GB of Kioxia NAND flash memory
Qualcomm SDX60M 5G modem
Most likely a Qualcomm SDR868 5G RF transceiver
USI 339S00761 WiFi/Bluetooth module
Broadcom AFEM-8215 front-end module
NXP Semiconductor SN210V NFC controller with secure element
If this doesn't satiate your chip ID appetite, check out our full roundup of iPhone 13 Pro chip ID to quench your thirst.
Is there a difference in memory between the 128gb and 256 or are they the same except for capacity
Up top we find the relocated earpiece speaker, complete with a cute little snoot. That snoot lives between the front-facing camera and Face ID hardware, and connects to a channel that directs sound out the top of the display.
While we love simple spring contacts, one of this speaker's standoff screws is trapped under the logic board, meaning you'll have to remove the board to swap the speaker! These layers are quite the repair ogre …
With its cables running underneath said earpiece speaker (which, again, is underneath the logic board) the front-facing camera hardware—enabler of the new, shrunken Notch™—is not exactly a piece of cake to access. But, at last, we have arrived!
After pulling out all the big-name bits, we spy something with its very own cut-out in the case metal. Our guess is that it's an Ultra Wideband antenna. Say hi, Find My!
Does anyone know what manufacturing process does Apple use to create the 90-degree holes and threads inside the iPhone? The ones on the bezels. They are visible in the second photo of Step 9. There are two screws holding a bracket for the slide switch assembly and also there is one on the top bezel of the phone (on the left side of the camera module held by the tweezers).
<br/>
Regular CNC cutting tools are not able reach inside at such an angle. Above the slide switch there are two other screws, but they are at about 30 degree and so a drill and a tap with a long toolholder can reach inside and clear the phone frame. But the slide switch holes appear to be impossible to reach this way.
<br/>
The only way I can think of is with an EDM die sinking process, but it’s incredibly expensive. Not that the iPhone is cheap, but for a couple of screw, I don’t think anyone could justify the cost!
<br>
<br>
Does anyone know what manufacturing process does Apple use to create the 90-degree holes and threads inside the iPhone? The ones on the inside of the bezels. They are visible in the second photo of Step 9. There are two screws holding a silver metal bracket for the slide switch assembly. Two other screws for the volume buttons, not visible here. Also there is one on the top bezel, on the left side of the camera module held by the tweezers.
Regular CNC cutting tools are not able reach inside at such an angle. Above the slide switch there are two other screws, but they are at about 30 degree and so a drill and a tap with a long tool holder can reach inside and clear the phone’s frame. But the slide switch holes appear to be impossible to reach this way.
The only way I can think of is with an EDM die sinking process, but it's incredibly expensive. Not that the iPhone is cheap, but for a couple of screw, I don't think anyone could justify the cost! The other option would be die casting and using threaded inserts.
About that front-facing camera: the dot projector has moved from the edge to the center of the module this year, but it also holds a little secret.
The flood illuminator, previously a part of the display—and a necessary component of Face ID—has been integrated into this new dual-purpose module.
With the display assembly now independent from Face ID hardware, you might be thinking display and Face ID swaps are easier than ever now! Right? Well, hold that thought.
Though you'll still get a not-so-friendly Important Display Message, and the new display will show up as an unknown part in the Parts and Service History.
Face id lock works on any faceid iphones? If i wanna buy used iphone XSm to be sure that screen wasnt replaced.
There are now videos claiming that screen replacement can be done without losing face id.
Face ID stinks. Finger print sensors for the win Apple.
Any idea if the issue can be fixed if the replacement was done before Dec 2021?
That's as far as today's teardown goes, disassembly-wise. But if we missed anything, you're bound to find it here: check out this 360-degree X-ray view.
Can you explain what are the 6 lines do in the side of the housing of the iphone? Is that just a design or does it do something?
The short answer is: Those are antenna lines. You’ll find lots of information on the web.
That's a lot of new things in a familiar-looking phone! So far we've seen:
A fancy new display, featuring not one but two upgrades: high/variable refresh rate technology, and a combination OLED+touch layer.
A migrated upper-speaker, further reducing the complexity of a display replacement, and making room for a smaller notch.
A return to the famous L-shaped battery in a non-Max-size phone.
A pretty devastating parts compatibility update that further violates your right to repair.
With all that in mind, how does this Pro iPhone 13 fare on the scale that matters most?
No mmW AiP in this I13Pro?
- Display and battery replacements remain a priority in the new iPhones' design.
- Most other components are modular and easy to access or replace.
- The multitude of screw types makes repair more difficult than necessary—but at least they’re not glue.
- Waterproofing methods complicate some repairs, but make (expensive) water damage less likely.
- Once again, double glass means double drop damage, and despite the improvements to durability over the years, there’s still no easy way to replace the rear glass.
- Software component pairing needlessly complicates many repairs, undermines credibility of third party repair, and reduces functionality of the device when repaired without Apple's proprietary calibration tools.
Laatste gedachten
Repareerbaarheidsscore
(10 is gemakkelijkst te repareren)
55 opmerkingen
The Taptic engine is getting smaller. Does that mean heavier rare-earth elements are used? Thank You very much!
It also noted it got larger, which it can do whist having a smaller footprint because the iPhone 13 is thicker than the iPhone 12.
If you get a ratio for the volume v weight, you get 159cmm per gram for the iPhone 12 Pro and 138cmm per gram for the iPhone 13 Pro so if anything it has less heavy metals as a ratio of its total volume.
iPostIt -
Thank You, Chris!
Check out out the X-ray out the 12 pro vs the 13 pro and you’ll see a major difference.
pretty sure it’s same as 13. 12 was just like 12 mini.
Does it make sense to upgrade iPhone 11 pro
max to iPhone 13 pro max?
I did. But only you can answer that. It’s a very noticeable upgrade…at least to me. I switched to a S21 ultra but had to return it because the camera was not as advertised. My 11 pro max took way better pics. I use my phone camera a lot so the 13 pro max is perfect for that.
I would suggest going from iPhone 11 Pro to iPhone 13 Pro. Not the Max. The 13 Pro is already a little bigger than 11 Pro. I got the 13 Pro Max and exchanged it for the 13 Pro. Max is quite heavy and unwieldy.
Great. Thank you for your response.
Can you swap the sim card reader with a dual sim card
No, you can’t: it is soldered to the motherboard.
There were some rumors on LEO chip. (For future iOS releases) Any trace of that?
These tear-downs are way more cryptic than they need to be. The text references multiple parts but doesn’t identify them in the photos. For instance, in step four, you reference both the iPhone 12 & 13, but don’t identify them in the photos. The reader is left to guess what you’re trying to illustrate.
I had trouble with this too. I appreciate that when it comes to the chip ID section, everything is color coded with outlines. Would like to either see the same color coding or a watermark on the photos for the model comparison bits so it’s easier to tell.
Was there any difference in the magsafe magnet array between the 4 iPhone 13s and the 4 iPhone 12s? Stronger/more magnets or anything?
Honestly, reading that display and battery replacements remain a priority, and that they are limited via software by apple, seem a bot of a contraddiction to me.
Can I straight up say that I’m not surprised iFixIt is giving false information about face Id on their site repair guide? There’s a way around it, and its happening on more models than just the 13. Its been stated endless times that its a bug in iOS 15, with the laundry list of other issues in ios 15
a way around the face id issue has been found
You are likely misinformed, everything I’ve read suggests that apple has intentionally disabled face id after third party screen swaps on the 13. There is a separate bug that breaks face id in ios 15, and a fix may have come out for that, but it’s not related to the intentional disabling, which is what Ifixit is referring to.
STOP PRESS!!!
Please take note of Hugh Jeffrey’s findings here:
https://www.youtube.com/watch?v=8s7NmMl_...
The software locks in this device are even worse than the ones found in the iPhone 12 series!
Replacement displays break automatic brightness
Replacement displays break Face ID
Replacement front cameras break the camera functionality
Plus all of the issues found in the iPhone 12 are still present
Revised repairability score: 0 (you’re lucky I’m not giving a minus)
Can someone tell me the antenna locations? Any ideas about putting a shield between the antenna and my ear/brain? The older models were easier to shield.
I was told by the Apple Store Berlin that the back glass of the iPhone 13 an 13 pro is now replaceable without changing the body of the phone. Can you confirm this?
%#*@, I’m always impressed by apple’s engineering they make such great devices but then they just go and make thing like locking Face ID to the screen or disabling True Tone, it really annoys me
How can you give it such a high rating when Apple locks out those repairs through software. Even if you use components from another iphone 13 I’ve read it will treat it like a counterfeit part. It doesn’t matter how easy it is to swap out modular components if the device locks out the new ones from functioning. This device deserves a 1/10 at most.
that is 100% true, i just seen note 20 ultra with score of 3/10, because of the adhesive, yet this guy https://www.youtube.com/watch?v=rHMOm_3w...
did it with no problem, i mean if you are lacking the skill to disassemble a phone that should be your rating, you have a skill that is 3/10, so at this point i think, apple money! This device deserves a 1/10 at most, because the only thing you could replace with out a problem FOR NOW is the case!
コメントありがとうございます!また、ご興味ある最新ガジェットがあれば分解ページを見にきてください。
I was searching for this in particular, is the camera module sealead because one of my camera glasses broke and I’m afraid it may compromise the rest of the device
A broken camera glass might be an entry point for dust and water to get into the phone not just the camera module. The camera module is somewhat sealed but the lenses need some space for OIS and this is where dust might not be welcome.
Is there any chance to replace just the camera cover glass? without whole back? I’ve got info from support they can replace it but only with whole back panel
Replacing just the camera glass should be possible if you find replacement. Replacing the whole back cover is a PITA since you have to swap all the internal parts (or at least quite a lot).
Great Information - thanks !
Hi.
Thanks for sharing information about .cell phone repair all phone repair information is help
me to understand that cell phone repair iPhone Reparatur
This received quite a high repairability score despite being impossible to repair by anyone other than Apple. Apple make by far the worst phones for if you want to be able to make any repair yourself or even a 3rd party repair shop (Samsung are also bad). This is very misleading as some consumers will make purchase decisions thinking they can replace a part if it breaks… iFixit lied to you… you ain’t replacing nothin’ son.
do you trust the devices that copy the serial number of old display and writes that to the new display to bypass face ID not working. If so which one would you recommend?
Tho I dont feel any difference on user experience for the new taptic engine.
This post is very helpful.
Thanks for sharing! word hurdle
Does anyone know what this cable is that’s attached on the right side of the logic board? (This cable is seen in the last photo above) . It’s attached to the back of the board and cannot be removed.
Wondering this too. I dug around some other sites as well as repair part sites and I think it's the 5g module/antenna flex?
Jordan M -
So I read through your tear downs for the 11, 12, and 13 and can’t seem to find any information detailing the difference in GPS specs. On Apple’s website the specs printed for the 11 say GPS/GNSS whereas the 12 and 13 explicitly mention GPS, GLONASS, Galileo, BeiDou satellite systems. I use my iPhone to navigate in the backcountry where there is no cell towers, WiFi, or other iPhones nearby, so the Wideband capabilities are not important to me. I am primarily interested in whether the 12 and 13 connect to more satellite systems than the 11 does. I currently have an 11 Pro Max. I use a handheld Garmin GPS as backup, but the iPhone has a lot of great navigation apps like Gaia, OnX and AllTrails.
can I replace my iPhone x battery with my iPhone xs?
has anyone made a teardown art for iPhone 13 pro max?
What you do is amazing. Can you tear down EVs in future? ;)
Great starting point, but missing some major bits. There's screws, grounding clips(?), a cable soldered to the backside of the logic board, and some other parts not mentioned in the video or text guide, but necessary to confront to fully disassemble. Maybe it's time for an update?
I want to ask where the prices of these phones can be consulted?
I want to ask where the prices of these Phone Price can be consulted?
Is there any way to fix the shell of an iPhone 13 that holds the front back and internals of the phone?
how to read puce nand flash memory of iphone13
My iPhone does not notify me when I receive a message
What can I do for the iPhone to notify me?
Hi, guys, could you add the Model number of this Iphone13 Pro ? A2483?
xiajinggai - Antwoord
