Gereedschappen die in deze demontage worden gebruikt
Inleiding
This is a teardown, meant for educational purposes, and not fixing. My school donated an old broken IDE hard drive to me to play around with and I want to put it to a good use. I figured people would find the inside of an old 3.5" hard drive cool, just as I did with the first one I disassembled (but didn't post a teardown for). Please note: It is HIGHLY advised to not disassemble any hard drive you plan on using again! Even a single speck of dust on one of the platters can destroy the entire drive, as well as all of your data! As well, I do not take any cautions to prevent ESD destruction to this drive, as it is already dead. Thanks for reading, and enjoy!
The first picture is of the top cover of the drive, and the second picture is of the PCB on the bottom side of the drive (which got cropped - I had to cut out a bit of the board. Sorry!)
Start by removing the six Phillips PH2 screws holding the top of the drive on. They may be a bit hard to loosen, as they're really old. Don't strip 'em! I couldn't get a good picture of all six screws to fit in the cropping area, but they are at the drive's four corners and also at the middle of each of the long sides of the rectangular body.
Peel off the stickers on the drive cover as well. This voids the warranty (who cares at this point?), but is necessary to expose the rest of the screws holding the cover on. Remove these screws also (there should be 2 torx TR7 screws and a 9/32" nut (circled in red in the third picture) - remove the nut as well - you may need a socket).
Now, pull off the drive cover. Pry where a yellow strip of sealing rubber appears. Pull off the drive's cover, and then move on.
Remove the four Phillips PH1 screws (circled in red) holding the PCB onto the back of the drive.
Disconnect the three ribbon cables still attached to the PCB (boxed in green in the first picture) by pulling the tabs (circled in red in the second picture) on the side of each ribbon cable "holder" away from the "holder" (See arrows - there are two tabs per ribbon cable "holder.").
Pull off the PCB from the back of the hard drive and remove the protective foam sheet from the back of the board.
Next, remove the two clear protective plastic stickers (circled in red) from the newly-exposed bottom of the drive.
Remove the nut that was previously enclosed under one of the stickers mentioned above (circled in orange) (I used pliers to remove it, as I was too lazy to grab another socket). It is a bit hard to turn, as it is glued on, but apply enough force and it will come off. Also, unscrew the brass set screw in the middle of the aforementioned nut.
Now, for the fun stuff! Let's remove the top platter first. Remove the six Torx TR6 screws (circled in red - one is behind my screwdriver) in the middle of the platter and then lift the ring (boxed in orange) in the center off. Then, slide the top platter out from under the read/write head (in the direction of the red arrows in the third picture).
Don't worry about being gentle at this point - you've already destroyed all of the data by simply opening the drive up.
Now, pull off the aluminum spacer (circled in red) in between the two platters (see the next step for a picture of this). We can't remove the second disk just yet, so let's move on for now.
Remove the three Phillips PH1 screws (circled in red) holding on the top Neodymium magnet. And be careful - they're pretty hard to get off! (I stripped one on accident and had to drill it out. This one is circled in orange in the second picture).
Now, pull off the top magnet.
Now, remove the two Phillips PH1 screws (circled in red) on the bottom magnet. Your magnet shouldn't have metal shavings on it like mine - this is only because I had to drill out the screw a bit ago.
You should now be able to move the read/write head (in the direction of the red arrows) enough to remove the bottom platter (pull it in the direction of the orange arrows.).
Now, you can pull on the metal tab (circled in red), and pull off both the read/write head and some of the ribbon cables. Lift straight up to detach the read/write head ("circled" in orange - follow the orange arrows). Now, you can remove the bottom neodymium magnet. Pull it straight up, and don't put it near the other magnet!
Now, remove the remaining Phillips PH1 screw (3rd picture circled in red) on the inner PCB and the three Phillips PH0 screws (3rd picture circled in orange) on the assembly right next to the inner PCB.
Pull the whole thing out (you have to remove the sticker strap on the outside of the drive. Pull off to remove the ribbon cables and detach the inner PCB assembly from the drive.).
Make sure to be careful at this step. I pulled too hard and shattered the mirror assembly, which is made of very sharp and very thin glass (The mirror is circled in green in the third picture.).
Use a pair of pliers to remove the brass/rubber standoff (circled in red in the first picture) and the plastic bar ("circled" in orange in the second picture) from the aluminum drive body. Pull hard and pull up.
Now, remove the three Phillips PH2 screws (circled in red) holding the drive motor to the body of the drive. Then, pull the motor straight up (in the direction of the orange arrows) and out of the drive body. Congrats - you're done!
See the last picture for all of the parts! (Minus the two screws I drilled out...) (You can further disassemble the read/write head assembly, but it shouldn't be too hard, right...?). Thanks for viewing!!
Agreed - I just got an old drive and thought some may want to see it. Quantum was bought by Maxtor in 2002 (and therefore stopped making their signature non-anodized silver drives at the same time). I've personally disassembled well over 150 hard drives ranging from 1990 to 2010, and have never had any mirrors or glass of any sort inside of the drives (This excludes the glass platters of 2.5" HDDs).
So you know how to remove the motor from HDDs that don't have screws? I don't know how there attached, there just sitting there somehow.
I apologize for the wait! (Haven’t been on iFixit in a few months, obviously!). Most modern drive’s motors are held in by screws and/or just a pressure fit, so even once you remove screws (if there were any to begin with), the motor may still seem to be stuck inside the casing. Try hitting it with a hammer a few times on the back of the drive and it should pop out; otherwise, I’d just say bolt-cut the casing to pieces so the motor falls out. Cheers!
Één commentaar
Tear down was interesting. Saved me the time of tearing down my Fantom 2T Green HD external drive. It quit and I was curious about replacing the hard drive inside. Yes, I removed all the data from the drive before it crashed permanently. Thankfully it gave a weeks warning. Thank you again. I appreciated the info.
