Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je MacBook Air 11" Mid 2013 te repareren, gebruik onze reparatiehandleidingen.
  1. MacBook Air 11" Mid 2013 Teardown, MacBook Air 11" Mid 2013 Teardown: stap 1, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown, MacBook Air 11" Mid 2013 Teardown: stap 1, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown, MacBook Air 11" Mid 2013 Teardown: stap 1, afbeelding 3 van 3
    • Thought we were done after the MacBook Air 13" Teardown? Think again; we've found another Apple for our bushel.
    • 4th generation Intel Core i5 processor with Intel HD graphics 5000
    • 128 GB flash storage (configurable to 512 GB)
    • 4 GB LPDDR3 RAM, configurable (but not upgradable) to 8 GB
    • 11.6" 1366x768 pixel display (~135 ppi)
    • 802.11ac Wi-Fi connectivity
    • Dual microphones
  2. MacBook Air 11" Mid 2013 Teardown: stap 2, afbeelding 1 van 2 MacBook Air 11" Mid 2013 Teardown: stap 2, afbeelding 2 van 2
    • If you're wondering what makes the 11" Air different from its bigger sibling, you're looking right at it.
    • The smaller 11.6" LCD has a slightly higher pixel density than the 13" model (135 vs. 128 ppi), but it's still nowhere near the Retina display that many were hoping for.
    • As with its larger sibling, the refreshed MacBook Air 11" retains the same model number as the 2012 iteration: A1465.
    • From the looks of the default icon, we're in 2013 an Air Odyssey. Open the pod bay doors, Apple.
    • I am sorry, iFixit, but I just can't do that.
    • Never mind, we're getting the Pro-tech.
    • We're hoping this unit is has a better lifespan than HAL's AE35 unit.
  3. MacBook Air 11" Mid 2013 Teardown: stap 3, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 3, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 3, afbeelding 3 van 3
    • The slim, trendy profile of the 11" model is identical to that of its 13" sibling, down to the new dual-microphone array.
    • It's a Pentalobe popping party!
    • Planning your own party? Don't be that guy—bring a Pro Tech Toolkit, you'll be life of the party.
    • Alright, party's over. Time to get inside.
  4. MacBook Air 11" Mid 2013 Teardown: stap 4, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 4, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 4, afbeelding 3 van 3
    • Comparison shots: 2012 edition (first image), 2013 edition (second image), overlay (last image).
    • The differences?
    • Smaller SSD module
    • No separate platform controller hub
    • New heat sink clamp
    • Different battery, same dimensions
    • Is there an echo in here?
  5. MacBook Air 11" Mid 2013 Teardown: stap 5, afbeelding 1 van 2 MacBook Air 11" Mid 2013 Teardown: stap 5, afbeelding 2 van 2
    • You want to talk about batteries? Let's talk about batteries.
    • While it doesn't get the "all day performance" of the 13" Air, the 7.6 V, 5100 mAh battery provides up to 9 hours of life in the 11" MacBook Air.
    • At 8.08 oz and 38.75 watt-hours, the new battery trumps last year's puny 7.90 oz module rated at 35 watt-hours and providing a measly 5 hours of battery life.
    • For comparison's sake, the 12-hour unit in the 13" model tips the scales at 10.35 oz.
  6. MacBook Air 11" Mid 2013 Teardown: stap 6, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 6, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 6, afbeelding 3 van 3
    • Yoink. There goes the proprietary solid state drive.
    • SSDs from MacBook Air models from top to bottom: 2012-11", 2013-11", and 2013-13".
    • It appears that the 2013 MacBook Air 11" uses the same PCIe-based SSD that we dug out of the 13" model. However, this particular drive is a SanDisk module, fitted with components from three different manufacturers:
    • SanDisk 05131 016G 16 GB NAND flash (four on each side, total of 8 x 16 GB = 128 GB)
    • Marvell 88SS9183 PCIe SSD controller
    • Samsung K4B2G1646E 2Gb DDR3 SDRAM
  7. MacBook Air 11" Mid 2013 Teardown: stap 7, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 7, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 7, afbeelding 3 van 3
    • The 802.11ac-equipped AirPort card is removed with ease.
    • A comparison between the AirPort/Bluetooth cards from the MacBook Air 11" Mid 2012 (above) and the MacBook Air 11" Mid 2013 (below).
    • The AirPort card comes equipped with exactly the same hardware as we found in the 13" Air:
    • Broadcom BCM4360 5G WiFi 3-stream 802.11ac gigabit transceiver
    • Broadcom BCM20702 Single-Chip Bluetooth 4.0 HCI solution with Bluetooth Low Energy (BLE)
    • Skyworks SE5516 dual-band 802.11 a/b/g/n/ac WLAN front-end module
    Hi, will any of the 802.11ac-equipped AirPort card's fit into the MacBook Pro Retina 15"?
    From looking closely and comparing with 'MacBook Pro 15" Retina Display Mid 2012 Teardown it looks like the 802.11ac AirPort card will physically fit in the MBPr (even if I have to glue it in I WANT 802.11ac in my MBPr :)
    The Antenna in the MBPr 15 (Late 2012) has the newer antenna's, so this should simply be a case of whether the port in the MBPr accepts the newer AirPort card?
    Could you please confirm??? :)
    If yes, then someone is going to be selling a LOT of these aftermarket '802.11ac' cards as a lot of people will want to upgrade to ac in their still very new MBP's....
    Thanks very much, I'm crossing my fingers :)
    Andy
    Andy - Antwoord
  8. MacBook Air 11" Mid 2013 Teardown: stap 8, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 8, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 8, afbeelding 3 van 3
    • Next we pull out the I/O board, and though it is similar to the one found in the 13" MacBook Air, it bears a more striking resemblance to a certain US state.
    • You may know that a lot of people consider themselves Apple fanboys. You may not know that Apple considers itself a Minnesota fanboy.
    • While on the opposite side of the board, the Cirrus 4208-CRZ audio codec is the same one found in the 13" model.
  9. MacBook Air 11" Mid 2013 Teardown: stap 9, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 9, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 9, afbeelding 3 van 3
    • Crank it up, it's about to get hot in here!
    • There go the nondescript speakers, followed by the redesigned heat sink.
    • These components are mere collateral damage to get to the logic board.
  10. MacBook Air 11" Mid 2013 Teardown: stap 10, afbeelding 1 van 1
    • The ICs on the front side of the logic board:
    • 1.3GHz (with Turbo Boost up to 2.6 GHz) dual-core Intel Core i5 processor, with integrated Intel HD graphics 5000
    • Intel platform controller hub (unmarked)
    • Intel Z244T011B Thunderbolt controller
    • Fairchild Semiconductor DD154P
    I really HATE this company. Everything is schemingly assembled to prevent ANY type of upgrading at all. Why should it be the only company allowed to do this? Still, people keep buying this crap from Apple...why? ASUS, HP, DELL, and many other build equal or quite superior devices. Most all of them allow for at least some type of personal upgrading to satisfy a consumer's personal tastes and/or needs. I really think that any "fair-minded" consumer should absolutely boycott all products made by this self-glorified, overly pretentious company. Then perhaps they'll be forced to relegate their designs to conform to many of the industry's standards, and stop vastly overcharging for products that are by no means superior, and in some cases inferior to many products offered by their competitors.
    Frank Ruhl Peterson - Antwoord
  11. MacBook Air 11" Mid 2013 Teardown: stap 11, afbeelding 1 van 1
    • Back side of the logic board:
    • Elpida F8132A1MC 8 Gb LPDDR3 RAM—(4 x 8 Gb = 32 Gb = 4 GB)
    • Hynix H5TC4G63AFR 4 Gb low power Double Data Rate III (DDR3L) Synchronous DRAM
    • Broadcom BCM15700A2
    • Texas Instruments TPS51980A synchronous buck controller
    • SMSC 1704-2
    • 980 YFC LM4FS1BH
    • Intersil 625 9AHRTZ
  12. MacBook Air 11" Mid 2013 Teardown: stap 12, afbeelding 1 van 3 MacBook Air 11" Mid 2013 Teardown: stap 12, afbeelding 2 van 3 MacBook Air 11" Mid 2013 Teardown: stap 12, afbeelding 3 van 3
    • Yep, those adhesive tabs are still around, and still annoying.
    • Kerpow! There goes the display assembly, finally free from the tyranny of the upper case.
    • The trackpad features the same chips we found on the MacBook Air 13":
    • STMicroelectronics STM32F103VB microcontroller
    • MXIC MX25L2006E 2 Mb serial flash
    • Broadcom BCM5976A0KUB2G trackpad controller
  13. MacBook Air 11" Mid 2013 Teardown: stap 13, afbeelding 1 van 2 MacBook Air 11" Mid 2013 Teardown: stap 13, afbeelding 2 van 2
    • MacBook Air 11" Mid 2013 Repairability Score: 4 out of 10 (10 is easiest to repair).
    • Once you get past the outer case, all the major components are fairly easy to access for replacement.
    • The outer case is held on with Apple's proprietary Pentalobe screws, so you'll need the right screwdriver to get inside.
    • Just like the screws, all the components—including the RAM and SSD—are proprietary, making replacement parts more difficult to source.
    • Worst of all, this MacBook Air is not upgradeable after purchase. Like many generations of the Air, the RAM is soldered to the logic board, and SSDs are not compatible between generations.
    What is the name of that ribbon wire that’s on the keyboard? It appears to be missing the end connector.
    SHAFIQAH SHARIF - Antwoord
8 opmerkingen
I love to see the front and back photos that you do of the logic boards. These components have a certain beauty to them, likely derived from the thoughtful engineering that was needed to create them. What is the purpose of the Hynix H5TC4G63AFR 4 Gb SDRAM? Is that for the Intel 5000 series graphics?
Eric - Antwoord
I don't think so. I've been trying to determine what it's for since the 13" teardown, and as I haven't found any references to Haswell's iGPU being able to use its own discrete memory (rather than main memory or the shared L4 like cache on the 5200), I'm thinking it has something to do with the Broadcom BCM15700A2.
Of course we then have a mystery as to what the Broadcom BCM15700A2 is for. As the only references to it I have found have been on these teardowns.
sendai -
is it possible to swap out the logicboard for a 2014 or 2015 model? will it work? please advise. thanks.
morrissummers - Antwoord
Yes, you can swap out the 2013, 2014 and 2015 into the same housings, as they are all the same, other than the ICs (CPU, etc...) on the boards being the difference. All the connectors and removable parts are all the same, including the display. I know it's a little later of a reply than you'd like. This is the same with the 13" Air models as well, 2013 + are all the same
Will -
Can you tell me the ic power on pad. Where it is located.thanks
Ifix4u - Antwoord
What is the screwdriver used to remove the airport card?
Adao - Antwoord
Hi Adao, it's a Torx T-5
hope dawson -
So good to see this but I am desperate to find the hard drive cable for this model. A1 465. I have searched everywhere but cannot find one….please help ?
Katie.
katie stevens - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 85
Altijd: 100,066
