Ga door naar hoofdinhoud
« Terug naar alle verhalen
Smashed and shattered
brook -
iOpener
Afbeelding van het verhaal
iOpener Instructions
30 seconden
Easy
Mijn probleem
To expensive to buy new, cheaper to replace broken part.
Mijn oplossing
Without the iOpener it was a fricken nightmare!!! You could over heat the unit with a heat gun and have to buy a new unit or use the iOpener and get it done in about a half hour, just like it says before you buy it. The glass stays together better, even where it is cracked when removing. Great tool, very simple and yet very effective.
Mijn advies
Before you even try to remove an iPad glass, jut spend the $20 you will be very glad that you did. Also this nifty tool can be use on all sorts of different units. You will definitely make your money back.
iOpener Afbeelding
iOpener
$24.95
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 65
