Ga door naar hoofdinhoud
« Terug naar alle verhalen
Nearly perfect home button replacement
platima -
iPhone 4
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
iPhone 4 Home Button Replacement
2 uren
Difficult
Mijn probleem
The previous home button was old, hard to press, and nearly impossible to double-tap. I also though a white button on a black iPhone would look pretty awesome.
Mijn oplossing
The repair wasn't hard, just took a while. Unfortunately when I put it back together though, the screen was on a slight angle and I have a thin tapered line at the top of the screen as a result (seen in the image).
Mijn advies
Yeah, video record what you do so you can play it back if you're unsure about clips, screws, etc. Also be careful that you don't move the LCD panel attached to the front glass and end up with the result I did!
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 245
