Ga door naar hoofdinhoud
« Terug naar alle verhalen
Goodwill iMac
john -
iMac Intel 17"
Afbeelding van het verhaal
iMac Intel 17" Power Supply Replacement
Moderate
Mijn probleem
I bought an iMac marked non-functioning from Goodwill. When I saw the specs on the bottom of the stand, I knew it had to be an Intel model. I grabbed it for $25 and took it home.
Mijn oplossing
As soon as I got my $25 iMac home, I plugged it in and found no signs of life. I popped it open and tested the power supply with a voltmeter; it was putting out nothing. I ordered the new power supply, popped it in, and my iMac was as good as new!
Mijn advies
Make sure you use a magnetized driver to remove the screws holding the screen — they're easy to drop into the iMac. Also, the EMI shield is a total pain. Other than that everything is pretty easy.
iMac G5/Intel Power Supply Afbeelding
$49.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 64
