Ga door naar hoofdinhoud
« Terug naar alle verhalen
Horrible support
Jared g -
iPhone 16 Pro Max
Afbeelding van het verhaal
iPhone 16 Pro Max Battery Replacement
3 uren
Moderate
Mijn probleem
My problem was I needed a new front camera so I purchased one labeled used was under the impression it would be able to be paired.
Mijn oplossing
I got the camera installed it went to Pair it in diagnostics and was told it was connected to a lost or ic account
Mijn advies
Tried to contact support all morning with no response none left with a mad customer and no idea on returning it or getting an exchange
7 opmerkingen
Unfortunately the front facing camera/aka the “TrueDepth” camera is paired specifically with the logic board in the phone and the only way to perform that pairing is through their self service repair store. The store won’t run the pairing software if you don’t have an existing order for the part you are attempting to pair. The camera for this specific repair is $151.24 for your reference.
Luke Grimes - Antwoord Deel
Based off of the packages label, I have a pretty clear idea to why it wasn't working; It's used! Be careful when purchasing used parts!
Theo Grefalda - Antwoord Deel
just new but need to know more
Otukene Raymond - Antwoord Deel
@princeunicorn Prior to the release of iOS 18, your statement was true, but on phones of the iPhone 12 and later generations, there is a Repair Assistant that runs when the phone detects a part that's been replaced. If it is a genuine Apple used part and the phone it originated from hasn't been reported lost or stolen, then the RA will pair the new part to the phone and of course it will always pair a new genuine Apple part with no issues.
Jerry Wheeler - Antwoord Deel
@jaredg82679 How did you go about trying to contact iFixit? Did you go through the FixBot assistant or email them at support@ifixit.com? I found them to be very responsive when I had an issue, so I'm surprised to hear about your experience.
Anyway, if I'm not mistaken most parts outside of batteries have a lifetime warranty, so your camera should be covered under warranty. Obviously that camera was harvested from a phone that was reported lost, and as such the Repair Assistant won't touch it. Wherever iFixit gets their used parts from, it's apparent that company didn't report that the phone was in "lost" status, and without the IMEI there's no way for iFixit to check that status.
So yes, you should still be able to return it for a refund or replacement if available.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 135
