Ga door naar hoofdinhoud
« Terug naar alle verhalen
Ring gen 2 repair
Clutha -
Ring Video Doorbell
Afbeelding van het verhaal
Ring Doorbell 1st Generation Battery Replacement
40 minuten
Easy
Mijn probleem
Our door bell failed and on inspection the battery charging socket looked contaminated by moisture. I cleaned it but the unit would only stay online for about an hour then indicated loss of WiFi
Mijn oplossing
Investigation went well using the guide on removing case.
I noticed the mesh indicated in the picture was displaced and not making contact with plate below it. On pressing it down it seemed to have adhesive on it to hold it in place. When closing the case I put two small pieces of thin packing foam on top of mesh to hold it down. Cover replaced and unit left online in house to help dry out any moisture. We’ve had storms & heavy rain humidity over 95%
Unit was ok for 3 hours so refitted outside
It has been 0degC overnight and it’s still working!
Mijn advies
You must have good small screwdrivers for case screws, a work mat that holds removed parts
3 opmerkingen
This is good, I will save it for future reference.
Ravikant - Antwoord Deel
Sounds good, it is very helpful.
Shower - Antwoord Deel
Thank you for this helpful guide!
Juan Colon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 428
