Ga door naar hoofdinhoud
« Terug naar alle verhalen
The little things
Buck Barfield -
MacBook Pro 13" Unibody Early 2011
Afbeelding van het verhaal
MacBook Pro 13" Unibody Early 2011 MagSafe DC-In Board Replacement
2 uren
Difficult
Mijn probleem
My MacBook wasn't charging right, so I cleaned the MagSafe connector, which revealed that the plastic surrounding the copper terminals was chipping off of the ends, exposing more of the copper. The computer still worked while the charger was connected, but I didn't get any type of charging light. I assumed that it wasn't the battery due to the visual inspection of the MagSafe connector on the computer.
Mijn oplossing
Definitely not the easiest project but was still manageable.
Mijn advies
Make sure all of the connectors are out of the way when you're putting the logic board back in. Also, the first time I booted up after the repair, my keyboard didn't work. A quick google search saved the day. The keyboard ribbon is very difficult to get back in, so use a piece of tape (I used duct tape) to grab ahold of the ribbon and help you push it back in!
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Afbeelding
$9.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 143
