Ga door naar hoofdinhoud
« Terug naar alle verhalen
The Growing Power Problem
Scott Stuck -
MacBook Pro 13" Unibody Mid 2012
Afbeelding van het verhaal
MacBook Pro 13" Unibody Mid 2012 Battery Replacement
5 minuten
Easy
Mijn probleem
As you can see from the photo, my old battery decided to hit puberty and started growing. To my surprise, the existing home we provided for that battery was too small. As a result, it decided to grow through the trackpad as quickly as possible.
Mijn oplossing
This was a super easy repair, albeit slightly scary because I was waiting for the battery to spontaneously combust. Simple removal of screws, one plug, then repeat in reverse order.
Mijn advies
None. If you are scared about doing a repair like this, don't worry. It is super easy and quick to do.
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery Afbeelding
$80.99
1 Opmerking
Hi Scott - Mine has grown through the trackpad as well. Did you end up replacing the trackpad or just the battery?
Kartic - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 572
