Ga door naar hoofdinhoud
« Terug naar alle verhalen
Spider Webbed Screen Easy Fix
Shanta Syal -
iPhone 6 Plus
Afbeelding van het verhaal
iPhone 6 Plus Screen Replacement
20 minuten
Easy
Mijn probleem
Badly shattered screen (glass shard hazards galore)
Mijn oplossing
It was a little tricky getting the suction cup to work on the severely shattered screen. It worked well enough to get the "Jimmy" in and pop the screen off. The magnetic screw driver in the kit was a bit annoying. It's pull is too strong. I had to place the screws by hand and use my fingernail to keep them in place so they wouldn't get jostled back out by the magnetic screwdriver tip.
Mijn advies
The glass was a real hazard. Easy to cut yourself on it etc. We found out that clear packing tape is a great solution to keep the glass shards in place (and it still allows you to use your phone while you wait for your iFixit replacement!). We also used clear shrink wrap and that worked as well! This was the .25mm thick stuff and the touch screen worked just fine.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 358
