Ga door naar hoofdinhoud
« Terug naar alle verhalen
Easy battery replacement
William Neuson -
MacBook Pro 15" Unibody Early 2011
Afbeelding van het verhaal
MacBook Pro 15" Unibody Early 2011 Battery Replacement
20 minuten
Moderate
Mijn probleem
My MacBook battery began to fail and expanded to the point of temporarily deforming the aluminum near the trackpad.
Mijn oplossing
Using the iFixit Pro Tech Toolkit, I followed the instructions in the step-by-step guide. The battery charged in a few hours and proceeded to work fine.
Mijn advies
In the event that the battery swells, remove the screws from the case closest to the failing section of the battery. Use a flat tool to carefully help the battery case out of the machine if the swelling is enough to deform the case.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery Afbeelding
$69.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 120
