Ga door naar hoofdinhoud
« Terug naar alle verhalen
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 uren
Difficult
Mijn probleem
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
Mijn oplossing
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Mijn advies
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
iPad Air Screen Digitizer Afbeelding
$29.99
1 Opmerking
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 166
