Ga door naar hoofdinhoud
« Terug naar alle verhalen
External Speaker Replacement
David Sikole -
LG G4
Afbeelding van het verhaal
LG G4 Speaker Replacement
5 minuten
Very easy
Mijn probleem
The external speaker no longer worked.
Mijn oplossing
Phone off. Pop the back cover starting at the charging port. It came off easy with my fingers. Take out the battery. Take out all the screws. The bottom assembly, external speaker, slides out. Discard the old part and slide in the part. Put the screws back in. Battery in. Cover on. Repair done.
Mijn advies
Small phillilps screw driver found with eye glass repair kits was my tool. Since the screws are so small, taking the screws out on a tray would be helpful. Also, be patiet when putting the screws back in
1 Opmerking
Good job,
Need wholesale LCD screen? https://txlcd.com/
txlcdsupplier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 95
