Ga door naar hoofdinhoud
« Terug naar alle verhalen
Xbox One Restoration
Dash Wilson -
Xbox One
Afbeelding van het verhaal
Xbox One Fan Replacement
40 minuten - 1 uur
Moderate
Mijn probleem
My Xbox One started to freeze up, warm up, and at some times, the fan started to scrape on the edges of it's bezel.
Mijn oplossing
The repair was a 9 out of 10 for me. The missing 1 is from one of the clips breaking, but that is not the tools' fault. Another thing is how locked on the fan was. However, it has not had any problems ever since I fixed it.
Mijn advies
Once you get the fan off, do not just go to the sink and rinse it off. either get some compressed air, or use a waterpik as I did (I do not recommend my way of cleaning unless you have no compressed air). BE CAREFUL! If you are not careful, you will break a clip on something, guaranteed.
1 Opmerking
I find a lot of fans benefit from oil on the bearings; I use engine oil.
Anwar Shiekh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 465
