Ga door naar hoofdinhoud
« Terug naar alle verhalen
Samsung Note 3 display replacement
Kevin Naquin -
Samsung Galaxy Note 3
Afbeelding van het verhaal
Samsung Galaxy Note 3 Display Assembly Replacement
10 minuten
Difficult
Mijn probleem
Had to swap displays to transfer data from Note 3 with inoperative screen ->to new Note 3.
Utilized a display from surplus Note 3 to temporarily repair Note 3 with damaged digitizer.
Mijn oplossing
Worked wonderfully...until I got to removing the USB board.
It seems the USB board is secured with adhesive. The picture shows a small pointed tweezers lifting the corner. This method did not work, and I managed to fracture the corner of the USB board. The damage did not affect operation of the phone whatsoever.
Removal of the USB board was not required in my situation, as this was a temporary fix, only to extract the data from a damaged Note 3. The display was returned to the phone whence it came from.
Mijn advies
You may want to mention a specific method of removing the USB board without damaging it.
Overall, I give this tutorial a 9.5 out of possible 10 points!
Thanks for the quality information!
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 237
