Mijn probleem
Daughter did another smashed screen
Mijn oplossing
I have done MANY repairs from iFixit (close to 60-70), and this was probably one of the more involved repairs. This is just unfortunately, the design of this specific phone. However, the guide was near perfect! and really helped. There was one problem I had, and the neatest part was the guide already covered the issue that could happen (not tightening the one screw tight enough). As soon as I put it together, I realized in two seconds what happened, and was able to fix it.
Mijn advies
There seemed to be a small problem with the kit. With the screw standoffs, they are very difficult to get out. There seemed to not be a tool included in the kit for this. Luckily, I had a very small screwdriver with an extra wide blade. The included flat blade screw driver did not fit these, although, I wound up never using the flat screwdriver, I think it was included because some of the phones may have a flat screw, rather than the pentalobe screws? If the flat screwdriver was for the standoffs, then its too small to use.
When I put things back together, even though I tightened these standoffs' I initally did have a battery problem. it turns out that the guide help identify the issue, but I realized that my standoff was still not tight enough. Even my small screwdriver with a wide blade still had a problem getting a good grip to get this screw tight.
0 opmerkingen
