Ga door naar hoofdinhoud
MacBook Pro 13" Touch Bar Late 2016 하단 케이스 교체
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 11 handleidingen die deze stap bevatten.
Stap 6
MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement: stap 0, afbeelding 1 van 3 MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement: stap 0, afbeelding 2 van 3 MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement: stap 0, afbeelding 3 van 3
  • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
  • Pull first at one corner, then the other.
  • Pull to the side—not up.
  • This can require a lot of force.
하단 케이스를 MacBook 전면을 향해 단단히 당겨 (힌지 부분에서 멀리) 하단 케이스를 고정하는 마지막 클립을 풀어주세요.
한쪽 모서리를 먼저 당긴 다음 다른 모서리를 당기세요
옆으로 당기세요—위로 말고.
이 작업은 많은 힘이 필요할 수 있습니다.
