Ga door naar hoofdinhoud
MacBook Pro 13" Touch Bar Late 2016 하단 케이스 교체
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 11 handleidingen die deze stap bevatten.
Stap 7 vertalen
Stap 7
MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement, Remove the lower case: stap 0, afbeelding 1 van 3 MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement, Remove the lower case: stap 0, afbeelding 2 van 3 MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement, Remove the lower case: stap 0, afbeelding 3 van 3
  • Remove the lower case.
  • To reinstall the lower case:
  • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
  • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
하단 케이스를 분리하세요.
하단 케이스를 다시 설치하려면:
디스플레이 힌지 근처 슬라이딩 클립을 제자리에 맞추고 정렬하세요. 커버를 아래로 누르고 힌지를 향해 미세요. 클립이 맞물리면 미끄러짐은 멈춰야 합니다.
슬라이딩 클립이 완전히 맞물리고 하단 케이스가 올바르게 정렬된 것처럼 보이면, 하단 케이스를 단단히 눌러 아래에있는 숨어있는 클립 네 개를 맞물리세요. 그들이 제자리에 끼워지는 것이 느껴지며 소리가 들려야 합니다.
